brendarinaman
#1 Posted : Monday, July 6, 2009 8:41:15 AM(UTC)
brendarinaman
When I get water from the water dispenser it continues to drip after I have finished dispensing water. This happens even if I "lock" the water dispenser off.
Any suggestions?
applianceman
#2 Posted : Monday, July 6, 2009 3:09:58 PM(UTC)
applianceman
This can be caused by air in the line, which can be caused by unhooking the line or changing the filter (if you have one). If you have recently done anything to cause air to be in the line simply run the water until all the air is out and it will be fixed. If this is not your problem I would say replace the water valve. Refrigerator repair guide
Water dispenser leaking (Refrigerator & Freezer Repair)
by belair1956 12/6/2014 10:15:24 AM(UTC)
Water dispenser leaks when ice maker fills (Refrigerator & Freezer Repair)
by Steenbockj 2/21/2013 10:06:36 AM(UTC)
GE Refrig water dispenser leaking (Refrigerator & Freezer Repair)
by tvlensman 1/14/2013 1:23:13 PM(UTC)
Front filter water dispenser leaking (Refrigerator & Freezer Repair)
by trogers2000 11/23/2012 10:42:13 AM(UTC)
Front filtered water dispenser leaks (Refrigerator & Freezer Repair)
by trogers2000 10/22/2012 3:47:38 AM(UTC)
Water dispenser leak!!! (Refrigerator & Freezer Repair)
by quidditchfan 9/11/2012 12:05:21 PM(UTC)
KitchenAid Water Dispenser Leak (Refrigerator & Freezer Repair)
by jedifan007 6/29/2012 8:06:39 AM(UTC)
Water dispenser leaking on Kenmore Coldspot side-by-side (Refrigerator & Freezer Repair)
by DBSmith 12/26/2011 4:26:26 PM(UTC)
refrigerator water dispenser leaks (Refrigerator & Freezer Repair)
by fridgedrip 10/19/2011 9:52:14 AM(UTC)
water line to water dispenser leaking at pump (Refrigerator & Freezer Repair)
by rfosterk 7/5/2011 12:46:58 PM(UTC)
Water Dispenser leaking (Refrigerator & Freezer Repair)
by rmulero 1/3/2011 9:05:46 AM(UTC)
Water dispenser leaks (Refrigerator & Freezer Repair)
by springerider 7/27/2010 3:30:06 PM(UTC)
GE fridge PS123SGMD water dispenser leaking (Refrigerator & Freezer Repair)
by slider14 7/12/2010 4:07:52 AM(UTC)
water dispenser leaks (yes I replaced the water inlet valve, filter, and installed s) (Refrigerator & Freezer Repair)
by david465 3/10/2010 5:27:17 PM(UTC)
Kenmore Refrigerator water dispenser leak (Refrigerator & Freezer Repair)
by hockey468 1/4/2010 10:34:33 AM(UTC)
