Shagslayer
#1 Posted : Sunday, July 5, 2009 5:18:17 PM(UTC)
Shagslayer
An ice layer builds up at the bottom of the freezer and prevents the door from closing completly. When the door seal is not seated properly when the door is not completly closed water is constantly leaking out from the bottom of the freazer door. Could there be a drain hole cloged or something? It might be possable that since this modle is frost-free and if a drain is cloged then the water from defrosing would lay in the bottom of the freezer and turn to ice.
woodchuckie
#2 Posted : Monday, July 6, 2009 5:41:33 AM(UTC)
woodchuckie
Yes, I think you have it figured out. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
GSS23HMHBCES - GE side-by-side (Refrigerator & Freezer Repair)
by rochacha 4/19/2023 12:04:59 PM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 9/28/2022 12:59:56 PM(UTC)
GE side-by-side running constantly? (Refrigerator & Freezer Repair)
by RCorley00 9/17/2014 9:41:06 AM(UTC)
GE Side-by-side Fridge stopped getting cold (Refrigerator & Freezer Repair)
by pflon 3/9/2014 3:37:58 PM(UTC)
changing motherboard on ge side-by-side (Refrigerator & Freezer Repair)
by av8or 9/10/2013 2:19:18 PM(UTC)
GE side-by-side not making ice, slow water dispensing (Refrigerator & Freezer Repair)
by sklim1 2/5/2013 8:20:30 PM(UTC)
GE Side-by-Side Water Drip (Refrigerator & Freezer Repair)
by jladd 7/30/2012 10:28:17 AM(UTC)
GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top (Refrigerator & Freezer Repair)
by jttaylor 1/23/2012 11:24:01 AM(UTC)
GE side-by-side ice-maker leak into freezer; ice dispenser not working (Refrigerator & Freezer Repair)
by SSWeinland 4/11/2011 8:40:31 AM(UTC)
ge side-by-side refrigerator (Refrigerator & Freezer Repair)
by Gennifer916 7/16/2010 11:22:33 AM(UTC)
GE Side-by-side freezer door hinge replacement (Refrigerator & Freezer Repair)
by kinsman 3/25/2010 8:18:50 AM(UTC)
GE Side-by-side Cooling Problem (Refrigerator & Freezer Repair)
by hansen.gk 3/1/2010 1:59:12 PM(UTC)
Evaporator Freezing GE Side-by-Side (Refrigerator & Freezer Repair)
by tforeman 2/23/2010 10:19:11 AM(UTC)
Ge side-by-side fridge too warm (Refrigerator & Freezer Repair)
by mcl143 11/10/2009 4:52:39 AM(UTC)
