Hello there, my dryer is making noise (it's working but is making a lot of noise), I opened it and I found the felt was out of place and ripped, what is the "felt" function on the dryer? I order a new one and now I need your help installing it, I want to ask you if you think guys this could solve the problem? I mean, changing the felt, if to do so please let me know if you can help me installing that felt. Thanks.
If you are toaking aobut the front felt, it is easy to install but hard to tell you how to put it, but it goes under the front plastic in a groove and then hooks over a plastic notch about half way up.
Good luck, keep trying and be patient and you should get it in.
