ecubulldog
#1 Posted : 16 years ago
ecubulldog
The dryer has stopped heating. Once the dryer is started it runs through its cycle like normal just no heat. I have tested the unit on low, medium and high heat, and none of the work. I have tested the the coil elemant with an OHM meter and there is no break. What else could be the problem?
sidfink43
#2 Posted : 16 years ago
sidfink43
Have you tested the thermostats/thermal fuses? If not, check them out and let us know what you find out.
Good luck
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 2 years ago
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 3 years ago
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 4 years ago
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 4 years ago
GE Dryer not heating up (Dryer Repair)
by Dryernoob 5 years ago
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 5 years ago
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 6 years ago
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 7 years ago
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 7 years ago
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 7 years ago
Dryer not heating (Dryer Repair)
by hoymanj 8 years ago
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 8 years ago
Maytag dryer not heating (Dryer Repair)
by Jmr721 8 years ago
Amana Dryer not heating (Dryer Repair)
by HnRmom 8 years ago
by tcdegener@yahoo.com 8 years ago
