tmt9663
#1 Posted : 16 years ago
tmt9663
Dryer has been working ok until few days ago- except extended drying time. Shuts off after 10-15mins, smells like burning rubber, took apart- fan area very hot, belt looks ok. We use both auto and timed settings. any suggestions would be appreciated. tina
sidfink43
#2 Posted : 16 years ago
sidfink43
Hi TMT
Well, it sounds like your motor is in the process of failing. It heats up, the burning smell is likely the motor overheating, and then the thermal protection on the motor shuts it down. After it cools off you can go through the same circle.
You will have to decide if you want to replace the motor and take the chance that replacement will fix it. It is not a difficult job, but it helps to have help (friend, neighbor etc) Here is the service manual.
http://www.servicematters.com/m...ary/docs/RS3200007R0.pdf
You should try a thorough cleaning of the machine with a vac and air blower if you have one before you replace the motor. Make certain all the air passages are clear of lint and there is no lint in the cabinet.
Good luck, let us know how it turns out
kayakcrzy
#3 Posted : 16 years ago
kayakcrzy
Amana dryers tend to build lint up in the blower housing. You might want to take the front off, and then remove the blower housing. There are four 5/16screws holding the blower housing to the frame of the dryer. Two on each side. You might want to clean that out, and while you are there, clean the top of the motor, so it can breath. Then give it try, before you buy a new motor. Tom www.applianceeducator.com:cool:
Microwave makes burning rubber smell (Microwave Repair)
by atlantic 2 years ago
LG WM2701HV smoking / burning rubber smell (Washer Repair)
by WhattaWasher 4 years ago
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 9 years ago
Washer grinding/burning rubber smell (Washer Repair)
by spjj@aol.com 10 years ago
Coupler replaced now burning rubber smell (Washer Repair)
by Crlee71 11 years ago
Replaced coupler, now squeaks and smells like burning rubber (Washer Repair)
by bosadi 12 years ago
Burning Rubber Smell (Washer Repair)
by emceeQubed 12 years ago
Washer not draining and getting burning rubber smell (Washer Repair)
by annette74 13 years ago
Maytag Commercial shook, made burning rubber smell, quit... (Washer Repair)
by JeffOYB 14 years ago
Washer smells like burning rubber and wont spin (Washer Repair)
by Davy99 14 years ago
Grinding noise and burning rubber smell (Washer Repair)
by eity 14 years ago
HELP.. please.. Washing machine and a burning rubber smell (Washer Repair)
by Amy Johnson 14 years ago
Whirpool w/ burning rubber smell stopped (Washer Repair)
by mjchevalier 15 years ago
