clay cunliffe
#1 Posted : 16 years ago
clay cunliffe
igniter glows but gas will not come out or light. could sensor be the problem or is there other parts that may cause gas valve not to open. I dont know if this may be an issue but i have been having problems balancing load in washer . It has been banging up against dryer. All conections seem to be fine.
clay cunliffe
#2 Posted : 16 years ago
clay cunliffe
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : 16 years ago
If the igniter glows but there is no gas then the problem most likely are a bad gas valve coils.
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for MAYTAG PYG2300AWW | AppliancePartsPros.com
