clay cunliffe
#1 Posted : Monday, June 29, 2009 10:27:16 AM(UTC)
clay cunliffe
igniter glows but gas will not come out or light. could sensor be the problem or is there other parts that may cause gas valve not to open. I dont know if this may be an issue but i have been having problems balancing load in washer . It has been banging up against dryer. All conections seem to be fine.
clay cunliffe
#2 Posted : Monday, June 29, 2009 5:41:16 PM(UTC)
clay cunliffe
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Monday, June 29, 2009 6:07:44 PM(UTC)
If the igniter glows but there is no gas then the problem most likely are a bad gas valve coils.
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for MAYTAG PYG2300AWW | AppliancePartsPros.com
