igniter glows but gas will not come out or light. could sensor be the problem or is there other parts that may cause gas valve not to open. I dont know if this may be an issue but i have been having problems balancing load in washer . It has been banging up against dryer. All conections seem to be fine.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
