mcdaniel1
#1 Posted : Sunday, June 28, 2009 11:08:37 AM(UTC)
mcdaniel1
so, i took the aggitator out and the grinding noise sounds like it is from the trans/ face seal area. at $250 for the trans and 72 for the face seal, am i crazy to fix this? or, just replace the seal and main bearing? or...?
magician59
#2 Posted : Sunday, June 28, 2009 7:17:38 PM(UTC)
magician59
These models tend to leak after a repair (even when repaired by a professional. Best choice is to spend that $250 on a good used Dependable Care model, or a Whirlpool/Kenmore.
Maytag Transmission Lubricant Capacity (Washer Repair)
by naabemgr 4/18/2015 4:38:42 AM(UTC)
Maytag transmission repair? (Washer Repair)
by skinnedknuckles 12/6/2011 3:36:46 PM(UTC)
Maytag transmission replacement (clothes washer) (Washer Repair)
by gabaugher 3/31/2011 10:43:52 AM(UTC)
Maytag transmission problem (Washer Repair)
by jameshere 11/28/2010 4:15:18 PM(UTC)
Maytag Transmission issue-Agitates in Spin Cycle (Washer Repair)
by davidaw 2/17/2010 4:12:10 PM(UTC)
How Maytag Transmission Work?? (Washer Repair)
by Winther 7/14/2009 4:59:47 PM(UTC)
how to remove metal collar sleeve on maytag transmission stem (Washer Repair)
by lex 12/2/2008 7:05:10 PM(UTC)
Maytag Transmission (Washer Repair)
by Dale Miller 6/30/2008 7:36:28 AM(UTC)
