dt611
#1 Posted : Saturday, December 17, 2011 3:14:40 AM(UTC)
dt611
Hi, how do you remove the face of the control panel?:confused: for my maytag model
MDE6200AYW
#2 Posted : Saturday, December 17, 2011 3:56:41 AM(UTC)
You have been a member since:: 2/29/2008(UTC)
Replacement parts for MAYTAG MDE6200AYW DRYER- ELE | AppliancePartsPros.com
Here is a manual
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
The wiring diagram for your unit is on page 10-25.
First I would check the power to the unit.
L1 to Neutral is the side of the line that runs the motor.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Next I would check the thermal fuses.
Unplug the machine and the wire/s at one side of the fuse. Then measure it with a meter, should be 0 ohms.
If the blower fuse (Item 10 in Section 6) is blown then the most likely cause is the vent system. Check/clean it, also be sure that the louvers outside the house open fully.
If the heater fuse (Item 11 in Section 5) is blown get back to us as there are a number of things that should be checked before replacing.
If the fuses are OK then I would check the start switch and the door switch.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
ApplianceJunk
#3 Posted : Saturday, December 17, 2011 7:07:36 AM(UTC)
ApplianceJunk
So what is wrong with your dryer?
dt611
#4 Posted : Saturday, December 17, 2011 10:22:31 AM(UTC)
dt611
the light is on, so i know that the dryer has power. when i press the start button, nothing happens. i have looked around to see where to remove the cover in the front of the dryer but it looks like all the screws are located in the back. can you tell me how to remove the panel?
#5 Posted : Saturday, December 17, 2011 12:45:13 PM(UTC)
I believe page 5-1 in the manual covers removing the front panel.
dt611
#6 Posted : Saturday, December 17, 2011 2:59:14 PM(UTC)
dt611
no, ok let rephrase, how do i get to the turn on switch so i can replace it?
#7 Posted : Sunday, December 18, 2011 4:37:17 AM(UTC)
Should be close to Page 4-2 in the manual.
Guest (6)
Dryer will not turn on, need wiring/hookup info (Dryer Repair)
by rsflores9 6/14/2014 3:06:00 PM(UTC)
Samsung Dryer will not turn on (Dryer Repair)
by jijake1977 6/11/2014 7:48:39 PM(UTC)
roper dryer will not turn on (Dryer Repair)
by MrTry2fixit 4/26/2014 6:49:16 PM(UTC)
by Beefer 9/11/2013 8:03:09 PM(UTC)
Ge Harmony Dryer will not turn on (Dryer Repair)
by bavism 11/24/2012 11:06:45 AM(UTC)
Dryer will not turn on. (Dryer Repair)
by MWalton954 10/25/2012 6:43:55 AM(UTC)
Kenmore dryer will not turn on (Dryer Repair)
by 3dDetailer 8/27/2012 3:06:35 PM(UTC)
by circlek 10/20/2011 1:58:43 PM(UTC)
Dryer will not turn on. Please HELP! (Dryer Repair)
by greatdeals_007 10/20/2011 6:57:18 AM(UTC)
by Davy99 9/7/2011 3:26:54 PM(UTC)
by nannyb 7/9/2011 5:12:33 AM(UTC)
by andreabowen 1/1/2011 7:01:05 AM(UTC)
by lndn82 7/11/2010 8:30:10 AM(UTC)
Dryer will not turn on has power other test done (Dryer Repair)
by KCgallimore 7/6/2010 12:24:10 PM(UTC)
by jkessler 4/12/2010 3:53:30 PM(UTC)
