My Dryer will not turn on. I checked the fuse box and it looks okay. Is there a fuse inside the dryer? could that be the issue? I had already replaced the timer and motor.
Any suggestions would be appreciated
Does your dryer have a touchpad user control panel? Our cabrio does and when we pressed the start button it wouldn't turn on. We took it apart and looked at the plastic casing that the circuit board fit into, the little part that engaged the start circuit had broken. I couldn't find the plastic part online and resorted to gluing the part...it's been working daily for 3 weeks. I'd still like to replace the plastic housing but not at the 255$ circuit board price.
