Beefer
#1 Posted : Wednesday, September 11, 2013 8:03:09 PM(UTC)
Beefer
I have power to chord. Tested 2 fuses and door switch. Thought it was motor? Still nothing. replaced timer, nothing. Now what? Is it possible that door switch or fuses test good but are bad? Yes I hold door switch closed and push on button but nothing happens? Any suggestions short of ordering the door switch and 2 fuses? Its an electric dryer.
HumboldtRepairMan
#2 Posted : Wednesday, September 11, 2013 8:14:56 PM(UTC)
HumboldtRepairMan
You check the start button for voltage and continuity?
Beefer
#3 Posted : Sunday, September 15, 2013 2:55:42 PM(UTC)
Beefer
I believe its part of the timer that i replaced
Beefer
#4 Posted : Tuesday, September 17, 2013 9:49:51 AM(UTC)
Beefer
The timer is the start button and its brand new
Dryer will not turn on, need wiring/hookup info (Dryer Repair)
by rsflores9 6/14/2014 3:06:00 PM(UTC)
Samsung Dryer will not turn on (Dryer Repair)
by jijake1977 6/11/2014 7:48:39 PM(UTC)
roper dryer will not turn on (Dryer Repair)
by MrTry2fixit 4/26/2014 6:49:16 PM(UTC)
Ge Harmony Dryer will not turn on (Dryer Repair)
by bavism 11/24/2012 11:06:45 AM(UTC)
Dryer will not turn on. (Dryer Repair)
by MWalton954 10/25/2012 6:43:55 AM(UTC)
Kenmore dryer will not turn on (Dryer Repair)
by 3dDetailer 8/27/2012 3:06:35 PM(UTC)
by dt611 12/17/2011 3:14:40 AM(UTC)
by circlek 10/20/2011 1:58:43 PM(UTC)
Dryer will not turn on. Please HELP! (Dryer Repair)
by greatdeals_007 10/20/2011 6:57:18 AM(UTC)
by Davy99 9/7/2011 3:26:54 PM(UTC)
by nannyb 7/9/2011 5:12:33 AM(UTC)
by andreabowen 1/1/2011 7:01:05 AM(UTC)
by lndn82 7/11/2010 8:30:10 AM(UTC)
Dryer will not turn on has power other test done (Dryer Repair)
by KCgallimore 7/6/2010 12:24:10 PM(UTC)
by jkessler 4/12/2010 3:53:30 PM(UTC)
