I have replaced the heating element and the thermal fuse and everything was working fine and now in the last two days, it has blown two thermal fuses. I belive that the thermostat is not regulating the heating element? Can anyone help?
Thanks very much!
Brian A.
Originally Posted by: Brian A  I have replaced the heating element and the thermal fuse and everything was working fine and now in the last two days, it has blown two thermal fuses. I belive that the thermostat is not regulating the heating element? Can anyone help?
Thanks very much!
Brian A. I just wanted to offer you support. I have yet to start this process but I am looking into my duet model # GEW 9200LL1's drying issues. I believe I need to replace the heating element. My dryer does not dry clothes completely, it's possible I need to replace the sensor as well. But it's been taking 2 60 minute cycles on Timed dry to dry a load with jeans. It never used to take that long. But it's old and I'm sure it is time for some things to wear like with the matching washer. I replaced the drain pump assembly and the front door gasket about a month ago. Good Luck, I'll be watching to see your progress.
