Brian A
#1 Posted : Sunday, June 14, 2009 7:46:41 AM(UTC)
Brian A
I have replaced the heating element and the thermal fuse and everything was working fine and now in the last two days, it has blown two thermal fuses. I belive that the thermostat is not regulating the heating element? Can anyone help?
Thanks very much!
Brian A.
frostywashdry
#2 Posted : Monday, June 15, 2009 5:51:57 AM(UTC)
frostywashdry
Thanks very much!
Brian A.
I just wanted to offer you support. I have yet to start this process but I am looking into my duet model # GEW 9200LL1's drying issues. I believe I need to replace the heating element. My dryer does not dry clothes completely, it's possible I need to replace the sensor as well. But it's been taking 2 60 minute cycles on Timed dry to dry a load with jeans. It never used to take that long. But it's old and I'm sure it is time for some things to wear like with the matching washer. I replaced the drain pump assembly and the front door gasket about a month ago.
Good Luck, I'll be watching to see your progress.
Whirlpool Duet dryer WGD9400 knob Removal (Washer Repair)
by Guest 1/1/2023 8:41:47 AM(UTC)
Whirlpool Duet Dryer Drum turning difficulty (Dryer Repair)
by DWMalcolm 2/6/2022 12:41:34 PM(UTC)
Whirlpool duet dryer issue (Dryer Repair)
by Wes13 12/15/2021 3:54:09 PM(UTC)
Duet Mod# GE9200LW1 Whirlpool Duet dryer (Dryer Repair)
by Guest 11/17/2021 6:59:07 PM(UTC)
Whirlpool duet dryer making clicking noise (Dryer Repair)
by Ctiong916 4/23/2021 9:00:11 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Whirlpool Duet dryer - no heat (Dryer Repair)
by colino 3/19/2018 10:56:53 AM(UTC)
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Whirlpool Duet Dryer Grinding Sound (Dryer Repair)
by mintken 10/16/2016 8:31:42 AM(UTC)
Whirlpool Duet Dryer won't start (Dryer Repair)
by berthettah 7/21/2016 10:10:39 AM(UTC)
Whirlpool duet dryer (Dryer Repair)
by norbreym28 7/16/2016 8:29:04 AM(UTC)
Whirlpool Duet Dryer F02 and F70 codes (Dryer Repair)
by esnyder 7/6/2016 1:18:43 PM(UTC)
Whirlpool Duet Dryer Error Code f25 (Dryer Repair)
by wwwhitley 10/30/2015 12:09:40 PM(UTC)
