mcdonneptdi1
#1 Posted : Saturday, June 13, 2009 4:09:12 AM(UTC)
mcdonneptdi1
I just ordered a door cam for refrigerator door on my side-by-side. Are they hard to install? The door will not close unless you really push on it to engage the magnet in the seal.
Thanks for the help.
woodchuckie
#2 Posted : Saturday, June 13, 2009 5:20:15 AM(UTC)
woodchuckie
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Door cam issues (Refrigerator & Freezer Repair)
by ISteveBMe 9/12/2020 12:31:16 PM(UTC)
Frigidaire Pro Series - Door Cam confirmation (Refrigerator & Freezer Repair)
by bucksuperstereo 8/3/2011 6:34:28 AM(UTC)
Kenmore Refrigerator Door Cam (Refrigerator & Freezer Repair)
by CrateBarrel 3/12/2011 10:34:34 PM(UTC)
Is Refridge. door cam 2 seperate cam parts that fit together or one single part? (Refrigerator & Freezer Repair)
by jbono111@aol.com 1/24/2011 12:46:55 PM(UTC)
door cam need replacing (Refrigerator & Freezer Repair)
by ready1 8/21/2010 5:54:26 AM(UTC)
Door Cam Riser (Refrigerator & Freezer Repair)
by BConley 5/10/2010 9:07:17 AM(UTC)
oven door came off (Oven Repair (including Ranges and Cooktops))
by TrishG 11/25/2009 9:36:55 AM(UTC)
