Hi all. I have a Kenmore 106.51133 210. it's a side-by-side freddy, and the right door cam isn't working well.
My problem is that the cam is adjusted incorrectly, and allows the door to "settle" at a position that's open too far. The reason it's a problem is that it bounces off the wall.
Anyone had this kind of a problem?
Is there a way to adjust the cam without taking the door off?
Sure hoping so......
Thank you.
