I just ordered a door cam for refrigerator door on my side-by-side. Are they hard to install? The door will not close unless you really push on it to engage the magnet in the seal. Thanks for the help.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
