DOUGHH
#1 Posted : Friday, November 25, 2011 3:22:09 PM(UTC)
DOUGHH
Washer will not pump the water out during the spin cycle..sometimes. Have put on new belts. (did to work better) After sitting off for a while, usually I can get the tub to pump out the water, works fine. It is doing this more often. Thanks for any ideas.
#2 Posted : Friday, November 25, 2011 7:01:01 PM(UTC)
Originally Posted by: DOUGHH Go to Quoted Post
...Washer will not pump the water out during the spin cycle..sometimes...
Does the motor run at that time?
DOUGHH
#3 Posted : Friday, November 25, 2011 9:31:53 PM(UTC)
DOUGHH
The motor seems to run fine, tub turns, belt to pump is new and seems to be working ok. Tub doesn't seem to get to top speed with all the water in it, the mass of water turning with the the tub. Waiting an hour or so, and starting the spin again usually works, outlet hose starts exhausting water immediately, tub speeds up as it empties, strong flow of water out, tub attains high rpms, shuts off.
DOUGHH
#4 Posted : Friday, November 25, 2011 9:32:25 PM(UTC)
DOUGHH
delete duplicate post
#5 Posted : Saturday, November 26, 2011 6:29:44 PM(UTC)
Make sure the belt tension is properly adjusted. The instructions are attached.
File Attachment(s):
Pump belt adjustment.doc (51kb) downloaded 3 time(s).
DOUGHH
#6 Posted : Sunday, December 4, 2011 7:18:19 PM(UTC)
DOUGHH
Thanks for your reply.
By pushing on the motor mounting plate, I can get the pump to work. Sprayed some wd-40 around it. Which parts might I need to replace? Thanks.
#7 Posted : Monday, December 5, 2011 2:31:23 PM(UTC)
Did you check the pump belt tension?
If the tension is fine, remove the belts and make sure the motor moves freely, back and force, and the springs maintain a proper tension on the assembly. If not, replace the roller kit.
- The roller kit Part number: AP4023752
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
