myoven
#1 Posted : 13 years ago
myoven
All controls are working properly. Lower oven works perfectly. Upper oven
fan for convection blows. Control panel shows oven is preheating however
it is not heating at all. No error codes. What part needs replacing? Thank you!
#2 Posted : 13 years ago
I am assuming that the unit stays in preheat and never comes ready.
Replacement parts for WHIRLPOOL GBD307PDB09 30" BUILT-IN ELECTRIC DOUBLE OVEN CONVECTION-UPPER SELF-CLEAN (GOLD LINE) | AppliancePartsPros.com
It could be that the control board is toast but more likely is that the thermal fuse (Item 37 in Section 2) for the upper oven has blown.
If you click on the parts picture a new page will open with a Q&A section.
Remove power from the unit and one wire from the fuse and measure it with a meter, should be 0 ohms.
Also here is a manual which should help.
KR-30 Whirlpool Electric Built-In Double Oven Service Manual - ApplianceDigest.com
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
File Attachment(s):
GBD307.pdf (518kb) downloaded 9 time(s).
whirlpool double wall oven BROIL on BAKE (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Whirlpool double wall oven lower not heating (Oven Repair (including Ranges and Cooktops))
by mid 3 years ago
Whirlpool Double Wall Oven Dead after Self Clean - Door Locked (Oven Repair (including Ranges and Cooktops))
by cmartin27 7 years ago
Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by PotRoastMan 10 years ago
by dragonflies64 11 years ago
Whirlpool double wall oven (electric) upper oven not working (Oven Repair (including Ranges and Cooktops))
by JayTeeC 11 years ago
Whirlpool Double Wall Oven (Oven Repair (including Ranges and Cooktops))
by abinosa 12 years ago
Whirlpool Double Wall Oven Fan (Oven Repair (including Ranges and Cooktops))
by bernardv 13 years ago
Removing trim and control panel from Whirlpool double wall oven (Oven Repair (including Ranges and Cooktops))
by Lifterfe 14 years ago
Whirlpool double wall oven E6 F2 code, then blank display (Oven Repair (including Ranges and Cooktops))
by jvr888 14 years ago
Whirlpool Double Wall Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by DaveinMD 15 years ago
by jledereich 16 years ago
Whirlpool Double Wall Oven D.O.A (Oven Repair (including Ranges and Cooktops))
by JaredB 16 years ago
Whirlpool Double wall oven DEAD after self cleaning cycle rbd306pd (Oven Repair (including Ranges and Cooktops))
by sillyshopper 17 years ago
Whirlpool Double Wall Oven - Top Oven Not Working (Oven Repair (including Ranges and Cooktops))
by bigguy 17 years ago
