tinkv192
#1 Posted : 16 years ago
tinkv192
I have a Whirpool dryer they is not working. The belts are fine, there is 220 going to the outlet, I Have the back off and all the connections looks fine. Could this be the Thermal Fuse? Any ideas of things to look for or what may go on a fairly new unit
#2 Posted : 16 years ago
The first thing I would do is check the thermal fuse for continuity. What is the complete model number of the dryer?
tinkv192
#3 Posted : 16 years ago
tinkv192
Gene, I will check tonight, when i get home, the Thermal fuse is a #3392519. Would that fuse show wear or some type of burn? It appears to be in good condition from the looks of it.
tinkv192
#4 Posted : 16 years ago
tinkv192
The model of my Whirpool dryer is LEQ9508PW1
gr33n3ggz
#5 Posted : 16 years ago
gr33n3ggz
I am having the same problems. Also I do get a light when the door is open and the actuator is not broken.
#6 Posted : 16 years ago
Sorry for the delay. There is no way to check it visually. It has to be checked for continuity or you can bypass it (much more risky) to see if the dryer will work.
Manufacturer part number 3392519 is Appliance Parts Pros part number AP3132867
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LEQ9508PW1 | AppliancePartsPros.com
#7 Posted : 16 years ago
If the problem and the model number of the dryer are the same then the troubleshooting is the same too.
Whirlpool dryer wont start (Dryer Repair)
by laundry1 10 years ago
Whirlpool Dryer Wont Start! Please HELP!! (Dryer Repair)
by KatharineF 11 years ago
whirlpool dryer wont start (Dryer Repair)
by klv 12 years ago
My Whirlpool dryer wont start (Dryer Repair)
by usmcmom09 13 years ago
Roper by Whirlpool Dryer Wont Start (Dryer Repair)
by cjduke 14 years ago
Electric Whirlpool dryer wont start (Dryer Repair)
by drew85205 15 years ago
by mercedes1 15 years ago
whirlpool dryer wont start in dry miser mode (Dryer Repair)
by tequilla 17 years ago
