tinkv192
#1 Posted : Thursday, June 4, 2009 5:29:16 AM(UTC)
tinkv192
I have a Whirpool dryer they is not working. The belts are fine, there is 220 going to the outlet, I Have the back off and all the connections looks fine. Could this be the Thermal Fuse? Any ideas of things to look for or what may go on a fairly new unit
#2 Posted : Thursday, June 4, 2009 10:07:20 AM(UTC)
The first thing I would do is check the thermal fuse for continuity. What is the complete model number of the dryer?
tinkv192
#3 Posted : Thursday, June 4, 2009 12:37:27 PM(UTC)
tinkv192
Gene, I will check tonight, when i get home, the Thermal fuse is a #3392519. Would that fuse show wear or some type of burn? It appears to be in good condition from the looks of it.
tinkv192
#4 Posted : Thursday, June 4, 2009 4:16:31 PM(UTC)
tinkv192
The model of my Whirpool dryer is LEQ9508PW1
gr33n3ggz
#5 Posted : Tuesday, June 9, 2009 6:58:30 PM(UTC)
gr33n3ggz
I am having the same problems. Also I do get a light when the door is open and the actuator is not broken.
#6 Posted : Wednesday, June 10, 2009 1:43:31 PM(UTC)
Sorry for the delay. There is no way to check it visually. It has to be checked for continuity or you can bypass it (much more risky) to see if the dryer will work.
Manufacturer part number 3392519 is Appliance Parts Pros part number AP3132867
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LEQ9508PW1 | AppliancePartsPros.com
#7 Posted : Wednesday, June 10, 2009 1:45:56 PM(UTC)
If the problem and the model number of the dryer are the same then the troubleshooting is the same too.
Whirlpool dryer wont start (Dryer Repair)
by laundry1 1/20/2015 11:46:37 AM(UTC)
Whirlpool Dryer Wont Start! Please HELP!! (Dryer Repair)
by KatharineF 11/11/2013 12:38:08 PM(UTC)
whirlpool dryer wont start (Dryer Repair)
by klv 7/30/2013 3:27:52 PM(UTC)
My Whirlpool dryer wont start (Dryer Repair)
by usmcmom09 2/15/2012 4:22:54 PM(UTC)
Roper by Whirlpool Dryer Wont Start (Dryer Repair)
by cjduke 7/30/2011 12:23:39 PM(UTC)
Electric Whirlpool dryer wont start (Dryer Repair)
by drew85205 11/5/2009 1:14:53 PM(UTC)
by mercedes1 9/17/2009 9:14:41 AM(UTC)
whirlpool dryer wont start in dry miser mode (Dryer Repair)
by tequilla 6/10/2008 3:06:03 PM(UTC)
