I have tested the thermalfuse, and the start switch. The door switch appears to work as the light goes on and off ( it also clicks) I have power in the correct amounts (240 v from l1 to l2, 120 from l1 to neutral, 120 from l2 to neutral). I attempted to test the timer ... some of the connections don't seem to give me the right results (if I am testing correctly) (bk to t has no continuity... no ohms shown), also bk to neutral has no continuity... no ohms displayed....
any ideas? Thanks.
whirlpool dryer will not start i replace thermal fuse the theramal cutoff kit and push to start switch still wont start
