Door switch good, their is no fuses in back of dryer how do i check timer?timer clicks when i turn it on
first thing to check is there 240 volts going to the dryer ,If so then check the thermal fuse for continuity to make sure it,s NOTopen.This is located in the back of the dryer,just take the back cover off the dryer it will be white in color.
Fuse is not open 0r broken
do you have a multimeter to check these parts i listed?
just curious if you have checked incoming voltage to the dryer ?
