Push start,:confused: timer ticks dryer wont start door loght comes on when door is open
first thing to check is that there is 240 volts going to the dryer.. Check your 2 fuses or breakers at your electrical panel. If ok there could be a therminal fuse that open, this is found in the back of the dryer,you have to take the back cover off to check [pull plug first] .IF ok check the door switch, should make a clicking noise..
