sagen
#1 Posted : Saturday, December 15, 2007 5:22:00 PM(UTC)
sagen
Push start,:confused: timer ticks dryer wont start door loght comes on when door is open
abbie
#2 Posted : Sunday, December 16, 2007 7:01:53 AM(UTC)
abbie
first thing to check is that there is 240 volts going to the dryer.. Check your 2 fuses or breakers at your electrical panel. If ok there could be a therminal fuse that open, this is found in the back of the dryer,you have to take the back cover off to check [pull plug first] .IF ok check the door switch, should make a clicking noise..
Dryer Wont Come On (Dryer Repair)
by Alan Egbert 7/10/2009 3:33:46 AM(UTC)
Dryer wont come on (Dryer Repair)
by sagen 12/16/2007 10:29:37 AM(UTC)
by sagen 12/16/2007 8:44:56 AM(UTC)
