sagen
#1 Posted : Sunday, December 16, 2007 10:29:37 AM(UTC)
sagen
Door switch good, their is no fuses in back of dryer how do i check timer?timer clicks when i turn it on
abbie
#2 Posted : Sunday, December 16, 2007 1:02:34 PM(UTC)
abbie
first thing to check is there 240 volts going to the dryer ,If so then check the thermal fuse for continuity to make sure it,s NOTopen.This is located in the back of the dryer,just take the back cover off the dryer it will be white in color.
sagen
#3 Posted : Sunday, December 16, 2007 1:56:27 PM(UTC)
sagen
Fuse is not open 0r broken
abbie
#4 Posted : Sunday, December 16, 2007 3:24:58 PM(UTC)
abbie
do you have a multimeter to check these parts i listed?
kawfeeman
#5 Posted : Sunday, December 16, 2007 5:44:17 PM(UTC)
kawfeeman
just curious if you have checked incoming voltage to the dryer ?
Guest (5)
Dryer Wont Come On (Dryer Repair)
by Alan Egbert 7/10/2009 3:33:46 AM(UTC)
Dryer wont come on (Dryer Repair)
by sagen 12/16/2007 8:44:56 AM(UTC)
by sagen 12/15/2007 5:22:00 PM(UTC)
