My dryer will Turn but the dryer does not heat up . What do I need to do to make my dryer work?
Hi Ashley Here is some things to check. 1. Determine if you have 120 volts coming to each side of your terminal block and 240 into the system. 2. Use the following parts diagram as a guide and check all of your electrical thermostats and fuses. http://manuals.frigidaire.com/p...f/Webster/5995380622.pdf3. Test the heating element for a break or for grounding. Good luck and let us know what you find out.
