My Icemaker Works But Recently The Cubes Are Much Smaller Than Usual. I Do Not Have A Water Pressure Problem But There May Be A Clog Somewhere?
Check the fill tube at the ice maker for partial ice blockage. Check the water supply mesh screen where it goes into the water inlet valve.
