dgholmes03
#1 Posted : Thursday, May 28, 2009 9:46:18 AM(UTC)
dgholmes03
Dryer getting extremely not. Replaced the thermostat limit, did not work, need to know where the other thermostat is. thinking that is the problem?
sidfink43
#2 Posted : Thursday, May 28, 2009 5:15:46 PM(UTC)
sidfink43
The most likely cause for an excessively hot dryer is some type of blockage in the venting. You should take it apart and thorough clean out the venting system, using compressed air if you have it, a vac if you do not. Make sure you take the cover off of the blower, and that you clean the venting system from the inside of the machine to the blower.
After you do this, operate the machine with the venting disconnected at the back and feel to see that you have a strong air flow.
If this does not solve your problem, post again and lets see what else we can look at. Do not operate the machine (other than to test) until this is fixed as excessive heat can be dangerous)
Good luck and let us know what you find out.
netsteeler
#3 Posted : Thursday, May 28, 2009 7:07:53 PM(UTC)
netsteeler
OOPS, sorry, posted new thread.
good luck with your problem Holmes. when I get mine fixed, I will re edit this post to tell you what the problem was.
sidfink43
#4 Posted : Friday, May 29, 2009 5:47:24 AM(UTC)
sidfink43
Hi Netsteeler
Please start a new post and also post your model name and model number and any other info you think can help us.
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
