ljticeman
#1 Posted : Monday, July 30, 2007 4:24:56 PM(UTC)
ljticeman
The lower element blew. I switched Off the main ckt breaker.
Once the lower element is replaced, the control panel does not (nor does any other feature) power up.....not even the clock. I have the panels removed and have the electrical schematic.......no fusable link found nor noted on the schematic. All other items check OK. Is there something embedded in the micro-ckt board that trips in lieu of a fuse? What could cause the total loss of power to the unit? (oh yeah, I turned the breaker back on and verified proper voltage at the receptacle)
Admin / APP Team
#2 Posted : Wednesday, August 1, 2007 2:52:14 PM(UTC)
Admin / APP Team
Rank: Administration
If the top burners work fine, then I'm pretty sure the clock board (control board) is fried.
- Click here for the replacement board (white color)
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
