The lower element blew. I switched Off the main ckt breaker. Once the lower element is replaced, the control panel does not (nor does any other feature) power up.....not even the clock. I have the panels removed and have the electrical schematic.......no fusable link found nor noted on the schematic. All other items check OK. Is there something embedded in the micro-ckt board that trips in lieu of a fuse? What could cause the total loss of power to the unit? (oh yeah, I turned the breaker back on and verified proper voltage at the receptacle)
Rank:: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
