my fridge wont get cold and my frezzer has ice in it it has only started since the weather has goten warmer and help would be great thanks
Is the whole back wall of the freezer covered with ice? If so it is a defrost problem either the defrost thermostat, defrost heater or the defrost timer. This page will tell you how to check them out. Note that if the ice is somewhere other than the back wall you may have a moisture problem (door gasket) or the drain may be stopped up. All three of these problems can cause the fresh food section not to cool. Refrigerator Not Cooling Repair Guide
