:( My Magic Cheg Oven Wont Heat Self Cleaning Part Works And Broiler Works Oven Does Not Light What Part Do I Need:(
Set it on a bake cycle with a setting of about 350* F
Check for 240VAC at the bake element. If it's there, but the element isn't working, replace the element. [COLOR="Red"]Handle it with care: One side of the element has a constant 120VAC going to it![/COLOR] Unplug the range or turn it off at the breaker before removing and installing the element.
If you don't get 240VAC at the element, there is either a broken or disconnected wire, or a bad relay on the control board.
