henson1166
#1 Posted : Saturday, January 5, 2013 5:08:07 AM(UTC)
henson1166
wont heat,set temp to 300.and push start fan comes on and thats it
onehotpny
#2 Posted : Saturday, January 5, 2013 10:30:04 AM(UTC)
onehotpny
Have you tried ohming out elements? need more info like model # and what you have tried so far.
#3 Posted : Sunday, January 6, 2013 2:29:23 AM(UTC)
The fan will run off of half the line (120 volts) but the elements require the full 240 so i would check the power first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Could also be the oven sensor if the control shows that the oven is ready.
Or could be your control board/timer is toast.
