wont heat,set temp to 300.and push start fan comes on and thats it
Originally Posted by: henson1166  wont heat,set temp to 300.and push start fan comes on and thats it Have you tried ohming out elements? need more info like model # and what you have tried so far.
The fan will run off of half the line (120 volts) but the elements require the full 240 so i would check the power first.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Check the voltage at the plug L1 to L2 should be 240 volts L1 to Neutral and L2 to Neutral, both should be 120 volts. If OK Unplug the unit and check the wires at the terminal strip in the machine to make sure none are loose or burned out If OK Check the power at the terminal strip. Do this with the heater off and on. [COLOR="Red"]Be careful as 240 volts is lethal !!![/COLOR]
Could also be the oven sensor if the control shows that the oven is ready.
Or could be your control board/timer is toast. |
THIS FORUM IS DEAD!!!!!!! |
