CLL
#1 Posted : Tuesday, November 8, 2011 9:11:49 AM(UTC)
CLL
:( My Magic Cheg Oven Wont Heat Self Cleaning Part Works And Broiler Works Oven Does Not Light What Part Do I Need:(
magician59
#2 Posted : Tuesday, November 8, 2011 10:00:30 AM(UTC)
magician59
Set it on a bake cycle with a setting of about 350* F
Check for 240VAC at the bake element. If it's there, but the element isn't working, replace the element. [COLOR="Red"]Handle it with care: One side of the element has a constant 120VAC going to it![/COLOR] Unplug the range or turn it off at the breaker before removing and installing the element.
If you don't get 240VAC at the element, there is either a broken or disconnected wire, or a bad relay on the control board.
Oven wont Heat up (Oven Repair (including Ranges and Cooktops))
by belliemom 2/28/2014 5:20:18 PM(UTC)
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 1/1/2014 5:52:03 PM(UTC)
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11/23/2013 8:55:12 AM(UTC)
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 5/7/2013 3:18:52 PM(UTC)
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 1/5/2013 5:08:07 AM(UTC)
lights come on oven wont heat up (Oven Repair (including Ranges and Cooktops))
by fxe81hd 5/3/2012 12:43:28 PM(UTC)
whirlpool oven wont heat up (Oven Repair (including Ranges and Cooktops))
by tim hinson 5/11/2011 3:49:42 PM(UTC)
Thermador Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by DonD 10/17/2010 8:53:15 AM(UTC)
magic chef wall oven wont heat up.it ignites (Oven Repair (including Ranges and Cooktops))
by barbara1 9/10/2010 2:01:00 PM(UTC)
Oven wont heat up after locking the door (Oven Repair (including Ranges and Cooktops))
by kescrig 8/10/2010 10:42:33 AM(UTC)
by bigdaddy5 4/25/2010 2:10:48 PM(UTC)
maytag oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Dan-o 3/30/2010 12:17:15 AM(UTC)
by mamoody 6/16/2009 5:29:34 PM(UTC)
oven wont heat up by itself (Oven Repair (including Ranges and Cooktops))
by garhd 8/9/2008 11:42:29 AM(UTC)
Kenmore gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by searvle 8/4/2008 1:17:30 PM(UTC)
