Vernitte
#1 Posted : Monday, December 10, 2007 11:20:09 AM(UTC)
Vernitte
My Oven Will Not Ignite. We Have Order From U And Installed The Oven Igniter. It Did Not Solve The Problem.
What Should Be Our Next Step . We Thought Maybe The Spark Module Might Be Bad. It Is Located Behind The Top Panel Behand The Dial That Turns The Temp To What U Need Or To Broil Or Clean.
Could U Please Advise What Our Problem Might Be. Thanks So Much
#2 Posted : Monday, December 10, 2007 4:55:44 PM(UTC)
The first thing I would check if 120V is coming to the igniter when the thermostat calls for the bake.
Make sure the both knobs are in the right position and are not broken.
Post your findings, please.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 5/21/2024 3:00:41 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
