ingrid1969
#1 Posted : Wednesday, November 2, 2011 1:41:47 PM(UTC)
ingrid1969
Hello - I have a Whirlpool Quiet Partner III model number GU2455. The pots and pans light and the normal wash lights are flashing. It won't start. I have unplugged it and tried to press normal again then the pots and pans light starts flashing again and the normal kicks in in a minute or so. Any suggestions? Thanks!
#2 Posted : Thursday, November 3, 2011 1:26:04 AM(UTC)
Sounds like either a control panel (keypad) or a control board problem.
Your model number is missing several digits at the end so I cannot find the correct tech sheet/wiring diagram.
The normal way to trouble shoot this is to check the keypad with a meter.
If it checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
You could try the following but it would be a long shot as it usually repairs open keys/connections and flashing is often due to always closed keys.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Need replacement control panel for Whirlpool Quiet Partner III (Dishwasher Repair)
by teewhile 1/18/2022 6:59:40 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
Whirlpool Quiet PArtner III leaking underneath (Dishwasher Repair)
by KareeHunt 8/26/2020 8:26:37 AM(UTC)
Whirlpool Quiet Partner iii stuck in wash cycle (Dishwasher Repair)
by WaltP 4/19/2020 9:47:42 AM(UTC)
Whirlpool Quiet PArtner III Pot/Pan light on and dishwasher will not run (Dishwasher Repair)
by DJ Chaffers 1/2/2016 6:13:21 PM(UTC)
Whirlpool Quiet Partner III gets stuck on a Normal cycle (Dishwasher Repair)
by jessman1128 10/27/2014 9:09:10 PM(UTC)
Whirlpool Quiet Partner III help (Dishwasher Repair)
by sjde 9/10/2014 4:42:56 PM(UTC)
Whirlpool Quiet Partner III - Door is loose; drops quickly; doesn't stay down (Dishwasher Repair)
by ESticker 7/2/2014 4:11:59 PM(UTC)
by mgmills 6/8/2014 7:58:45 AM(UTC)
by tinymrf 8/21/2013 1:02:57 PM(UTC)
Whirlpool Quiet Partner III thermal fuse blew after replacing heater element (Dishwasher Repair)
by dieseldaddy 6/4/2013 4:40:34 PM(UTC)
whirlpool quiet partner III blinking lights (Dishwasher Repair)
by rwhans007 11/27/2012 1:09:54 PM(UTC)
Whirlpool Quiet Partner III Won't Start (Dishwasher Repair)
by hendricksd 10/23/2012 12:28:03 PM(UTC)
WhirlPool Quiet PArtner III (Dishwasher Repair)
by jbrantl8 9/4/2012 4:54:21 AM(UTC)
No lights on Whirlpool Quiet Partner III (Dishwasher Repair)
by johnctln 8/14/2012 6:59:27 AM(UTC)
