Hello - I have a Whirlpool Quiet Partner III model number GU2455. The pots and pans light and the normal wash lights are flashing. It won't start. I have unplugged it and tried to press normal again then the pots and pans light starts flashing again and the normal kicks in in a minute or so. Any suggestions? Thanks!
Sounds like either a control panel (keypad) or a control board problem.
Your model number is missing several digits at the end so I cannot find the correct tech sheet/wiring diagram.
The normal way to trouble shoot this is to check the keypad with a meter. If it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
You could try the following but it would be a long shot as it usually repairs open keys/connections and flashing is often due to always closed keys. Connector Cleaning / Checking Unplug the unit Open it up Remove the ribbon cable from the keypad to the control board at the control board. Clean the edge connector. If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here. Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates. Reconnect everything and give it a try. |
THIS FORUM IS DEAD!!!!!!! |
