marc74or
#1 Posted : Monday, May 11, 2009 4:42:03 PM(UTC)
marc74or
I have a whirlpool dryer model leb6200pqo and it stopped working. I checked and the thermal fuse is bad. It says if that is bad I should replace the thermal fuse and the operating thermostat. Which one is the operating thermostat? If I by pass the thermal fuse the machine comes on but no heat. I checked the element and it is good. So does that mean I do need the operating thermostat too? Or do I need a thermal cutoff too?
kayakcrzy
#2 Posted : Tuesday, May 12, 2009 4:34:57 AM(UTC)
kayakcrzy
It would most likely be a the thermal fuse. Do you not have a ohm meter? The operating thermostat is the 4 wire thermostat. It will most likely not be the culprit. Tom ApplianceEducator.com
#3 Posted : Tuesday, May 12, 2009 4:58:18 AM(UTC)
Replacement parts for WHIRLPOOL LEB6200PQ0 | AppliancePartsPros.com
Here is a wiring diagram
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Check that you have 240 volts at the plug.
The heater and the timer require 240 to operate. It is not uncommon to loose half the line without actually tripping the breaker.
Turn the breaker off/on slowly a couple times.
I assume that you checked it with a meter.
Did you remove both wires from the heater and check between them for resistance, should be approximately 10 ohms. And also then check from each terminal to the case, to ensure you do not have a grounded element.
Check both of these with your meter.
Both should be 0 ohms at room temperature.
Note on your operating thermostat one set of connectors are the switch contacts (0 ohms), the other set is an internal heating element used to change the temp settings of the dryer (approximately 7,000 ohms)
Since the thermal fuse blew it is important to check/clean the blower wheel and your vent system.
marc74or
#4 Posted : Tuesday, May 12, 2009 6:02:47 PM(UTC)
marc74or
thanks for the info I found the problem it was the thermal fuse
#5 Posted : Wednesday, May 13, 2009 2:46:55 AM(UTC)
Glad you got it fixed.
Have a good day
Dryer Repair Again and Again (Dryer Repair)
by Guest 6/25/2022 3:48:47 PM(UTC)
WHIRLPOOL Dryer Repair Kit (27 Inch Wide Dryers, Thin Twins) - AP3109602 (4392067) (Dryer Repair)
by try2repairguy 12/9/2021 6:57:53 AM(UTC)
Dryer repairs (Dryer Repair)
by P3FE 10/16/2021 2:36:49 PM(UTC)
Whirlpool Dryer Repair Mishap (Dryer Repair)
by Clanky3 3/19/2020 12:26:10 PM(UTC)
Dryer Repair Issue (Dryer Repair)
by jdharrin 10/2/2019 1:32:57 PM(UTC)
THIS IS A 'PICKLE', on my dryer repair (Dryer Repair)
by Polly147 2/2/2018 5:35:41 PM(UTC)
Dryer repair Help! (Dryer Repair)
by Hah45 10/4/2017 2:39:32 AM(UTC)
Frigidaire dryer Gallery series wont heat in Dryer Repair. "dryer turns but no heat (Dryer Repair)
by darien685 8/24/2016 11:36:06 AM(UTC)
dryer repair Amana (Dryer Repair)
by rlblaxstick@aol.com 12/26/2015 12:03:59 PM(UTC)
Dryer Repair (Dryer Repair)
by sotomargie 12/21/2015 9:44:35 AM(UTC)
Dryer repair (Dryer Repair)
by dchurch 9/26/2015 8:38:17 AM(UTC)
by jaybick 8/24/2015 6:34:15 AM(UTC)
Cordless screwdriver for dryer repair ? (Dryer Repair)
by dog_at_work 10/13/2014 10:54:09 AM(UTC)
by Tom Campion 4/14/2014 6:20:19 AM(UTC)
by kencorey281@gmail.com 11/12/2013 2:35:48 PM(UTC)
