dogwood
#1 Posted : Thursday, December 6, 2007 3:35:12 PM(UTC)
dogwood
The GE Profile washer is 18 months old. The machine timer cycled to spin but did not. I found the technician sheet inside the back panel. Was able to use the control panel (press start and whites button simultaneously) to identify the spin cycle as the problem, then over-rode the timer and it worked fine. But it will not cycle through on regular cycle or quick spin cycle on its own.
Any thoughts as to what needs replacing?
#2 Posted : Thursday, December 6, 2007 5:08:34 PM(UTC)
Most likely the problem is a bad control board.
You should run the troubleshooting as described in the tech sheet.
dogwood
#3 Posted : Monday, December 10, 2007 6:00:40 PM(UTC)
dogwood
The control board was OK. It turned out the washer level valve air hose was clogged with "biologicals". A little cleaning followed by a bleach bath did the trick and everything is running fine now. Thank you anyway.
Dogwood
crwriter
#4 Posted : Tuesday, August 4, 2009 8:13:59 PM(UTC)
crwriter
Can you give me the codes indicating problems? E4 is blinking and 05 does not respond at all. I hate to tear the machine apart just to get this information. :(
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 12/27/2015 12:35:03 PM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin during final rinse (Washer Repair)
by Asu19 10/28/2015 2:38:21 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE washer won't spin (Washer Repair)
by Dana021 4/28/2014 5:05:18 PM(UTC)
GE Washer Won't Spin - Lid Lock Error? (Washer Repair)
by lum 1/30/2014 11:41:30 PM(UTC)
GE Washer won't spin dry clothes (Washer Repair)
by jglascoe1691 12/10/2013 4:41:11 AM(UTC)
GE washer won't spin/agitate (Washer Repair)
by Mlsmith 10/8/2013 5:30:10 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
GE washer won't spin - Mark (Washer Repair)
by masavrin@netzero.net 1/2/2013 9:45:50 AM(UTC)
by the5tjrs 11/2/2012 9:01:04 AM(UTC)
GE Washer won't spin with heavy loads (Washer Repair)
by paulgj 10/18/2012 8:00:50 PM(UTC)
ge washer won't spin (Dishwasher Repair)
by magsw 5/24/2012 3:12:19 PM(UTC)
ge washer won't spin or wash, no blinking lights on motor (Washer Repair)
by fr45 2/28/2012 9:22:19 AM(UTC)
GE Washer won't spin but agitates (Washer Repair)
by guptamgs@hotmail.com 1/5/2012 11:29:15 AM(UTC)
