Setting clock then selecting AM to PM does not register on touch screen. Clicking "More Choices" touch screen button brings up Clock reset screen.
Originally Posted by: murielh  ...Setting clock then selecting AM to PM does not register on touch screen... What exactly happens when you tried to do it? Gene.
Gene, I can enter the time using the number keys, but the one button that represents AM/PM does not register a finger touch. The default is AM.
There is also a FINISHED button that does not register the finger touch. I have to push START to accept the time.
There is a touch button called MORE CHOICES. When I select it, the 'reset clock' screen appears.
Yes, the correct part number would be extremely helpful. The touchscreen is green/yellow with black text. Your help is much appreciated!
What is the color of the control panel?
