murielh
#1 Posted : Monday, October 10, 2011 12:43:09 PM(UTC)
murielh
Setting clock then selecting AM to PM does not register on touch screen.
Clicking "More Choices" touch screen button brings up Clock reset screen.
#2 Posted : Monday, October 10, 2011 3:23:38 PM(UTC)
Originally Posted by: murielh Go to Quoted Post
...Setting clock then selecting AM to PM does not register on touch screen...
What exactly happens when you tried to do it?
murielh
#3 Posted : Tuesday, October 11, 2011 3:38:10 AM(UTC)
murielh
Gene, I can enter the time using the number keys, but the one button that represents AM/PM does not register a finger touch. The default is AM.
There is also a FINISHED button that does not register the finger touch. I have to push START to accept the time.
There is a touch button called MORE CHOICES. When I select it, the 'reset clock' screen appears.
#4 Posted : Tuesday, October 11, 2011 2:35:28 PM(UTC)
Sounds like the problem is a bad touch pad. It comes as a part of the control panel. If you need the correct part number, post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GH6177XPB3 MICROWAVE HOOD COMBINATION | AppliancePartsPros.com
murielh
#5 Posted : Wednesday, October 12, 2011 3:11:34 PM(UTC)
murielh
Yes, the correct part number would be extremely helpful.
The touchscreen is green/yellow with black text.
Your help is much appreciated!
#6 Posted : Wednesday, October 12, 2011 7:57:20 PM(UTC)
What is the color of the control panel?
Guest (4)
