murielh
#1 Posted : 14 years ago
murielh
Setting clock then selecting AM to PM does not register on touch screen.
Clicking "More Choices" touch screen button brings up Clock reset screen.
#2 Posted : 14 years ago
Originally Posted by: murielh Go to Quoted Post
...Setting clock then selecting AM to PM does not register on touch screen...
What exactly happens when you tried to do it?
murielh
#3 Posted : 13 years ago
murielh
Gene, I can enter the time using the number keys, but the one button that represents AM/PM does not register a finger touch. The default is AM.
There is also a FINISHED button that does not register the finger touch. I have to push START to accept the time.
There is a touch button called MORE CHOICES. When I select it, the 'reset clock' screen appears.
#4 Posted : 13 years ago
Sounds like the problem is a bad touch pad. It comes as a part of the control panel. If you need the correct part number, post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GH6177XPB3 MICROWAVE HOOD COMBINATION | AppliancePartsPros.com
murielh
#5 Posted : 13 years ago
murielh
Yes, the correct part number would be extremely helpful.
The touchscreen is green/yellow with black text.
Your help is much appreciated!
#6 Posted : 13 years ago
What is the color of the control panel?
