lspitz
#1 Posted : Wednesday, October 5, 2011 4:03:21 PM(UTC)
lspitz
My Refrigerator is freezing food
#2 Posted : Thursday, October 6, 2011 3:07:29 AM(UTC)
Replacement parts for MAYTAG MTF2172HRB REF - TOP MOUNT | AppliancePartsPros.com
Is the compressor cycling or always on, other than when it is in a defrost cycle.
If always on then the most likely culprit is the thermostat.
Get a thermometer and check the temperature in the freezer. It should be 0 to 5 degrees F.
If too cold turn your temperature control to a warmer setting.
Wait at least 24 hours to re-check the temperature.
If the freezer is full it may even take longer.
If the temperature does not change then I would replace the thermostat.
Does the fresh food temperature dial actually open/close the damper (Item 1 in Section 2). Click on it's picture for a better view of it.
LG LFX31925ST Refrigerator is freezing (Refrigerator & Freezer Repair)
by rick1911 2/24/2021 10:30:14 AM(UTC)
Frigidaire 'Tall Twin' Refrigerator is freezing food. (Refrigerator & Freezer Repair)
by jbeal9 6/24/2020 12:23:53 PM(UTC)
refrigerator is freezing, freezer seems fine (Refrigerator & Freezer Repair)
by ichellema 8/5/2019 5:05:40 PM(UTC)
GE Refrigerator is freezing fresh food side (Refrigerator & Freezer Repair)
by MikeHam 2/1/2016 7:40:49 PM(UTC)
Electrolux All-Refrigerator is Freezing (Refrigerator & Freezer Repair)
by rousseau 12/1/2015 3:08:31 AM(UTC)
by Jd52981 8/23/2015 5:45:28 PM(UTC)
by bdeforce 10/2/2014 4:26:01 AM(UTC)
Refrigerator is freezing food (Refrigerator & Freezer Repair)
by weldmeister 4/14/2014 10:14:26 AM(UTC)
Magic Chef Refrigerator is Freezing everything (Refrigerator & Freezer Repair)
by vincecnj 11/9/2013 8:05:52 AM(UTC)
by blarge 10/15/2012 9:20:28 AM(UTC)
Refrigerator is freezing foods - temp controlls have not been touched in years (Refrigerator & Freezer Repair)
by wmundy 9/14/2012 8:49:20 AM(UTC)
Refrigerator is freezing food in the fresh food compartment (Refrigerator & Freezer Repair)
by KodiakJim37762 5/24/2012 8:29:24 AM(UTC)
Refrigerator is freezing all liquid (Refrigerator & Freezer Repair)
by runaway043 2/25/2012 6:05:26 AM(UTC)
refrigerator is freezing food (Refrigerator & Freezer Repair)
by uptomealso 10/2/2011 7:59:37 AM(UTC)
Refrigerator is freezing foods (Refrigerator & Freezer Repair)
by lrobb 7/27/2011 6:41:24 PM(UTC)
