My dishwasher quit working and would not start. I found the ribbon from the control panel to the ckt board intially to be a problem as I unplugged it and plugged it back in and it ran one complete cycle each time. I did this several times with the same result, one cycle each time. I then ordered a new control panel that comes with the ribbon, plugged it in and again the same results. I check the continuity on the door switch and it is operating correctly. I now have ordered a ckt board as I figured the problem was within the J1 connector on the ckt board, but this has not solved anything. I called the CSR as was wondering why they offered a ckt board and a ckt board kit. Is it possible there is two different ckt boards due to a sn break or something. Any help would be appreciated. Thanks
THIS FORUM IS DEAD!!!!!!! |
