handyman216
#1 Posted : 17 years ago
handyman216
Timer went bad in mid cycle, washer stayed in wash cycle for hours. I replaced the timer, which now works fine. However it now appears that little or no water is getting into the machine. Could water pump/motor have burned out when the timer went bad? I can hear water running when the machine calls for it, but when I open the washer, very little water is evident, top rack items bearely wet, liquid detergent not even disolved. Does this sound like a pump/motor problem or a bad water valve?
#2 Posted : 17 years ago
Remove the bottom panel and check the drain solenoid (on the left side of the pump).
A bad timer could damage a solenoid and if it stuck in the drain position, then water running in and out at the same time.
- The part number for the drain solenoid AP2039683
- Here are the break down diagrams for the GE dishwasher Model GSD3220Z02BB
handyman216
#3 Posted : 17 years ago
handyman216
Should the drain solenoid move freely when power is off?
#4 Posted : 17 years ago
Yes. It should.
handyman216
#5 Posted : 17 years ago
handyman216
It does not move up or down. Does this confirm that a new solenoid is needed?
#6 Posted : 17 years ago
No doubt!
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew about a year ago
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder about a year ago
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 2 years ago
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 2 years ago
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 3 years ago
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 3 years ago
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 3 years ago
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 3 years ago
Maytag Washer - no water (Washer Repair)
by maalfunction 3 years ago
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 4 years ago
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 4 years ago
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 4 years ago
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 5 years ago
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 5 years ago
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 5 years ago
