handyman216
#1 Posted : Wednesday, November 28, 2007 7:09:16 PM(UTC)
handyman216
Timer went bad in mid cycle, washer stayed in wash cycle for hours. I replaced the timer, which now works fine. However it now appears that little or no water is getting into the machine. Could water pump/motor have burned out when the timer went bad? I can hear water running when the machine calls for it, but when I open the washer, very little water is evident, top rack items bearely wet, liquid detergent not even disolved. Does this sound like a pump/motor problem or a bad water valve?
#2 Posted : Wednesday, November 28, 2007 7:20:03 PM(UTC)
Remove the bottom panel and check the drain solenoid (on the left side of the pump).
A bad timer could damage a solenoid and if it stuck in the drain position, then water running in and out at the same time.
- The part number for the drain solenoid AP2039683
- Here are the break down diagrams for the GE dishwasher Model GSD3220Z02BB
handyman216
#3 Posted : Wednesday, November 28, 2007 8:38:57 PM(UTC)
handyman216
Should the drain solenoid move freely when power is off?
#4 Posted : Wednesday, November 28, 2007 8:50:40 PM(UTC)
Yes. It should.
handyman216
#5 Posted : Wednesday, November 28, 2007 8:53:39 PM(UTC)
handyman216
It does not move up or down. Does this confirm that a new solenoid is needed?
#6 Posted : Wednesday, November 28, 2007 9:01:20 PM(UTC)
No doubt!
Guest (4)
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
