markmachlis
#1 Posted : Saturday, September 17, 2011 10:26:44 PM(UTC)
markmachlis
I am not getting any water. I changed out the water inlet valve and cleaned all the inside parts. When the cycle should call for water...none comes through the valve. Any ideas?
#2 Posted : Sunday, September 18, 2011 3:45:22 AM(UTC)
Replacement parts for WHIRLPOOL GU940SCGQ2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Did you check that the float (Item 32 in Section3) is not stuck in the up position. Sometimes gunk etc. can get in there and hold it up.
Did you check that the float switch (Item 30 in Section 3 ) is activated.
The float (overfill) switch is wired in series with the water valve so if it is not closed then you will not get water.
If it looks OK then remove power from the unit and one wire from the switch and measure it with a meter, should be 0 ohms.
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
