I am not getting any water. I changed out the water inlet valve and cleaned all the inside parts. When the cycle should call for water...none comes through the valve. Any ideas?
Here are your parts Replacement parts for WHIRLPOOL GU940SCGQ2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.comDid you check that the float (Item 32 in Section3) is not stuck in the up position. Sometimes gunk etc. can get in there and hold it up. Did you check that the float switch (Item 30 in Section 3 ) is activated. The float (overfill) switch is wired in series with the water valve so if it is not closed then you will not get water. If it looks OK then remove power from the unit and one wire from the switch and measure it with a meter, should be 0 ohms. |
THIS FORUM IS DEAD!!!!!!! |
